\'79 F-250
I may be able to get my hands on a '79 (I think, but it's that genre) F-250 2 wheel drive (I know it isn't a 4x4, but am not sure where else to go). I don't know much about Ford gas engines (I'm a diesel guy), so I have some questions about it.
It has a 351 (he said "Cleveland"; not sure what exactly that means) that's been torn down to the timing chain. The chain was replaced (maybe the gears too), but has been sitting open for at least a year (he never had time to put it back together).He said there may be some rust on it all now. Could that pose a problem? How difficult is it to put everything back together? The radiator may have been yanked for space to get to this, but I don't know either way. In addition, the carburetor was apparently replaced (it's a work truck, so I'm assuming it's a 2bbl; any other opinions?).
It has an automatic transmission; what tranny is it? I'm guessing it's a C6, which I've heard is pretty bulletproof. Also, what rear end was available on this truck? I'm wondering about type (Dana? Ford-made? What?), gearing (which was available and how to tell the difference) and whether or not it's posi.
And, for the real kicker...how reliable is the engine/trans/diff combination for this truck? I've had bad luck with gasoline engines and, if it weren't for the fact that my diesel Scout's developing a real bad case of blowby, I wouldn't even consider this. Thoughts? Opinions? I know this truck has taken some abuse; it used to belong to a construction company. And I don't know the mileage, but it's probably pretty high. I need a truck that's relatively trouble-free and can run long distances (i.e. from the SF area to the LA area) on a fairly regular basis with little to no trouble, but can't afford very much (otherwise I'd be buying a 6.9 powered Ford or a Cummins powered Dodge).
Thanks in advance!
The Warden
1980 International-Harvester Scout II SD-33T
The Warden
