1 - 1 of 1 Posts
Had to remove my carburetor and automatic linkage, where it attaches to the carburetor today. Need to remove the valve cover to replace a push rod and rocker arm. Push rod had gone through the rocker arm. Only problem I have is that I didn't take pictures or make drawings of how all the levers, rods and springs go. I also had to disable the bracket that attached to the intake manifold and holds some of these linkages. Needed to do this so I could get the valve cover off on the drivers side as my body has settled do to Michigan's rust.
Could someone please post some pictures or drawings of this setup so that I can get my Ramcharger back together.
Thanks,
Bill
1 - 1 of 1 Posts
