Guest
·\'77 CJ7 engine help?
Can someone help me here?
My 77 CJ& inline 6 258 cid was driving along happily with me, when it decided to cut out. A few minutes later it decided it was ready to restart. I had this problem once again, and then it was fine for a half hour or so. Then two short blocks from my house, the Jeep decided to go belly up on me. At an idle, it was a little rough when it was running with some backfiring. I had just rebuilt the carb, replaced fuel pump, and I checked to make sure it was getting gas. I then checked to see if it was getting electricity, and hooked a timing light up. Nothing came through the timing light. I have a prestolite point type distributor, I have tried replacing the ignition coil and ignition module and I have not cured the problem. Can anyone tell me what is going on, or what to look for? I am about to hit a brick wall here, because I cannot figure what is going wrong. Please help me!
