Hello.
First A Little Background on the vehicle in question:
76' Ford F-250 Highboy 4x4
4 Speed Tranny
Divorced NP-205 Transfer Case
Dana 60 Rear Dana 44(?? I am pretty sure) Front Axle
4.56 Gears With Limited Slip In The Rear
Stock Wheels (16.5") With Stock Size Tires
Misc Mods:
2 Generic KC Wanna-Be's Bolted To Front Bumper
Roll Bar With 3 KC Daylighters (one rear facing)
1/4" Steel Rear Bumper With 3/4" Hitch Welded To Frame
Cammo Paint Job Curtesy Of Krylon Spray Bombs
2.25" Exaust With Glass Pack Muffler (No Cat)
SunPro Mechanical Gauage Set Oil Pres/Temp/Amps
SunPro Tach
The Engine:
Original 300 i6
Non Egr
Rebuilt Carter YF 1bbl manual choke(From older model truck?)
6" open element air filter setup.
Now to the problems now that ive gotten all that out of the way:
I bought the truck off a small junkyard who used it to drag cars around with. The truck only has 133k on it and had not been licenced since 1982! When I first got it I had alot of fuel starvation problems which i tracked down to a defective pickup in the gas tank(Perhaps why it had been in a junk yard so long). Anyway I tuned it up new pcv valve, plugs wires etc, carb rebuild, belts hoses.. Replaced a couple broken brake lines(rear brakes where the only ones that worked) Got plates and insurance and tested my luck out on the road. I only paid $100 for the truck(WHAT A DEAL HUH?) Anyway the first 300 miles or so it ran good leaked a little oil but otherwise was strong and didn't smoke. Besides some stearing play and a rattling throw out bearing everything seem ok. One day when I got brave and decided to take it on my 50 mile one way commute to work, It started smoking real bad under the hood. No loss of power or oil pressure I still get 25/30lbs at cruising speeds. Anyway I am getting excesive oil and smoke blowing out my pcv system on the end that is supposed to draw air in. I have a new pcv valve and checked the vacumm port on the intake for clogging and everything was fine. I have to run with the breather element out of the rear of the valve cover to prevent oil from pushing out of all the seals. Which i still get alot of smoke comming out of the rear hole of the valve cover. I Had to run a hose from the hole for the breather element through an anti-freeze jug to catch all the oil that blows out to prevent more underhood mess. Still the engine has not lost power and does not smoke out of the exaust system. Could this possibly be a stuck ring from it putting around in a junk hard for 22 years and me taking it out on the highway? 60mph = about 3100rpm in 4th gear. Also right before this problem started I changed the oil The old oil looked like crap smelled like crap and was very thin. I replaced it with Havoline 20-50 and a new fram filter. I own a 91 f150 2wd with a 300 and 240,000 miles on it and have never had any problem from the engine, its never been overhauled and goes oil change to oil change without using anymore than 1/2 a quart and i change it every 5k and average 500miles a week. This is why I wonder if my problems with this truck can be fixed or do I need a rebuild?? 130k dosen't seem like much for a 300..
Also If I do rebuild this engine how do flat-top pistons and 4bbl intakes with perhaps a 600cfm edelbrock work on a 300? I've never been able to find anyone that has modified a 300 so I don't know if its worth the trouble? I catch a lot of flack from the 302 guys about having a 300 in both my trucks and it sure would be nice to be able to show them up without spending a fortune. Also i thought about swaping a dual exaust manifold setup of an injected 300 Any power gains there? On my 91 f150 I am running true dual exaust with 2" pipes thrush glasspacks, And no cat (No vet testing in my area and my cat...lets just say it fell off) which seems to have added some low-end tourque and improved gas mileage. Sounds kinda funny and makes alot of noise between 2000 and 3500 but it was well worth it. I've also flipped my air box over and cut the bottom out so I can get more air to the filter(Can't find a K&N kit for my funky 2 air tube to one air box filter setup). Can anything else be done to my efi truck to improve performance? Also it has a speed limiter which is very anoying on the interstate anyway to disable this? I have very high gears and a 5 speed and i can get it up to the speed where it cuts off in 3rd!.
Well I am sorry that I have asked so many things in one post but i have so many questions to ask and nobody I know messes with 300's. Any help would be greatly appreceated.
Thanks!
4 Speed Tranny
Misc Mods:
SunPro Tach
The Engine:
Original 300 i6
Non Egr
Thanks!
