I think I broke my toy again..
I was playing on some hills and heard a loud bang in my rear end. I got it out to a parking lot, but it would only go foward in 1st gear and reverse. It wouldn't go foward when in 2nd, or drive.
When I got it home (trailer), I took off the rear diff cover and saw that the welded spider gears had some missing welds and broken teeth.
I figured that that was my problem. Too much bind in the rear to allow it to shift..
Well not now, I installed a spool and tried to drive it, and same problem. Fluid is ok and the kickdown is still adjusted properly. I even put it in drive and went to the front and added pressure to the kickdown cable, but still no go.I do hear a whine when in drive and it wants to pull, but no pull. Even with throttle it isn't pulling.
here is what it is...401/727/d300.
Anyone??
Thanks, Ricky...seeya...
Anyone??
