I have a project wagoneer going that I want to swap to big block mopar, so I recently aquired a 413. The guy says it has 516 heads on it, and I don't know that much about mopar. Are these heads anything special?? My plans are to use the truck for towing/moderate 4wheeling, I want to run pump gas with torque at off idle to 3 or 4 grand. I don't see this engine seeing much above 4000 rpm very often. The 413 bottom end is suppose to be stock with about 30k miles on it. One head is suppose to have a "maybe problem" with a valve, would I be better off to rebuild these heads or swap to something else?? Any response appreciatted, TIA a bunch.
