Yep, the body lift is most likely causing your shifter to hit the tunnel cover befor you fully engage 4 hi. Pull up you carpeting and take a look. It will be an easy fix, just enlarge the opening in the tunnel cover. BTW, get rid of that 3" body lift, IMO that's too much for a CJ, get a susp. lift. 1-2" at most on the body
