Can anyone help id the following closed knuckle
front end and rear end, on an alleged '68 f-250 4x4?
Front End top 34430
Front End bottom (upside down) 44 68F
Rear End top (upside down) C80255
Rear End bottom 60
Also, the transmission has no back up light switch.
Does this mean it is off an earlier truck (how early)?
The engine is a 360 with a 1976 date; allegedly
a replacement for the original 360.
Thanks!
I have owned several of these early trucks.Tough as a damn tank.On the front you got both Dana 60's and 44's.Sounds like yours is a 44 from the numbers.The rear is a Dana 60.On the New Process 435 and Warner T-18 the switch should be on top at the back.If not it's from an earliet truck.The only problem I had was getting mud in the knuckle and eating up the bearings where they turn at.
1996 F350 SRW 4X4 POWERSTROKE 4"LIFT 4:10 38"GROUND HOGS FULLY CUSTOMIZED
1979 BRONCO 460 C-6 205 3:50'S 33"THORNBIRDS
PROJECT CJ7 ON HOLD
