I have a 90 with the same setup. My vaccum lines were burned through because of some acid for my battery. I tried doing my own patch job but my check valves were messed up. If you still have them use rubber tubes that you can get a local auto supplier. I'll have to go check my setup to see how the lines match. Personally I would suggest getting a new harness. It is about $40 but only Jeep dealerships supply them.Easy to install. The only problem I have now is that that vaccum to the motor doesn't work. I'm still trying to figure out why. I'll write you another message s to the line match.
