Re: 401 is dying at stops and low speeds occasiona
Yup -- explosive!!! I nearly lost an eye when one blew up on me. Part of the cap hit me in the face knocking me silly.
The Prestolite was a very poor excuse for an ignition - or starting and charging systems. But they were cheap!
The Motorcraft really wasn't great either, but far better than the Prestojunk.
The Motorcraft (Duraspark) ignition has an output the same as a points type ignition, just no points to wear.
Upgrading to a HEI module greatly increases the output - a noticable difference.
The HEI module can operate with the Ford TFI coil (the square one,) or the round DuraSpark II coil, or preferably the GM HEI remote coil - more "snap", and the ignition resister is eliminated, so there's lots more power in the system.
Using the larger cap is not absolutely required, but it's a good mod. The larger cap has the terminals farther apart so it's a better High Voltage insulation, plus you can use the better insulated 8MM wires.
(The later Ford DuraSpark II and the TFI were much better, far more reliable and had the same ouput as the GM.)
For those wanting to retain the "stock look" you can hide the GM module somewhere and use the original cap.
GM first came out with the standard HEI in '75, by '77 I was already retrofitting the modules into Ford and Chrysler systems - even into a couple of Porches, some Fiats, Jags, Mercedes, all kinds of stuff. I even developed a points driven HEI conversion for purists -- but I was never happy with it.
He He -- Later on some of the Fiats, Subarus, and Jags had a big ugly looking heatsink they called the "module" - Fiat & Subaru was around $700, Jag was about $1200. Pry off the back cover and you found a stock $35 GM module!!!!
I recently suggested using the remote HEI on the Offroad.com Short Wheelbase board. Since then several guys have done it - a couple of great write-ups have resulted from it - pics and all. All of them have reported great improvements in starting and driveability. Do a search.
Specs:
Points type, Prestojunk, Motorcrap:
28-32 KV available voltage.
.75 MS spark burn time.
GM HEI:
35-40 KV
2.5 MS burn time
About 3 times faster rise time.
A faster rise time helps fire the plugs - can even blast crud off an electrode. The same principle that makes CD's work so well - like the MSD. Kinda like using an impact wrench on a stuck bolt.
The longer burn time helps get more particles of fuel burning at the right time -- like using a bigger match to light the BBQ. Problem with MSD is the burn time is extremely short - the nature of a CD. The MSD's "multiple firings" are only at low R's too, below about 2000 RPM. There's not enough time between the short firings to discharge then recharge the capacitor at the higher speeds. Even then, MSD's a definate improvement over any stock ignition except HEI.
Some aftermarket coils claim 50, 60, even 80 KV output. Of all the aftermarket coils I've seen, and that's a bunch, none have ever exceeded 40 KV - same as stock. Of course I didn't test the output like they must have by using 36 volts to drive it! Many take the stock GM coil and pot plastic around it to change the appearance. Crack it open and find a stock coil!
Since it runs on 12 volts, if you were to increase the turns ratio to increase the output voltage, the output current would proportionatly reduce. It would have the same energy.
The "performance modules" are the same way -- who would believe a company like Accel, DUI, or Bubba and Yahoo would spend the millions of dollars to develop a new chip and mount it on the same plate just to sell a few at Autozone?
The next step up from the HEI in performance is a Direct Ignition System. Since each individual cylinder, or pair of cylinders use a separate coil, charging time for the coil is longer - more energy can be packed into it - for a much better spark. There are a few being made now for racing -- but very very high $$$$. The increase in performance on those is at the very high R's, like 10,000+ RPM.
Something very important -- use the stock original plugs -- do not use the plugs from an engine that uses the HEI. The plugs are designed to match the combustion chamber, not the source of ignition. Avoid the aftermarket trash - "Made to sell, not to use." Things like reach, heat ranges (throughout the entire operating range) and indexing are all considered when the designers selected the plugs to use.
Simply open the gap a bit more to expose the mixture to more spark area -- because you can now!
Sorry for the long post and shotgunning info.
