Guest
·I have posted this on the SWB Jeep mailing list also so I apologize if you end up reading it more than once.
1. If I wiggle my front axle shaft and there is play in it does the mean that I should change
the U-joint's? I ask b/c the shaft hits the tranny whenever I flex the suspension too much
vertically. I have the Q-tac, and this was apparently a problem with the 1976 CJ-7. The
transfer case is lowered about an inch already and I do not want to lower it anymore. I
think, if I don't do anything about this, it will just eat up u-joint's and all around not be
good. I had an idea about just going to a machine shop and having them take a 1" piece of
square tubing, and make a block to extend the bump stop down lower.
2. On a 1976 CJ-7 where do the wires go on the back of the oil pressure gauge in
relationship to the driver?
3. What the heck is the difference between an AGC fuse and an SFC,SFE,whatever,
fuse?
4. My girlfriend has a Honda accord. i told her I would change her plugs/wires/carp/etc. If
the manual calls for her plugs to be gapped at .044 and my gapper has a setting at .045 will
it make a difference?
Lee R. Byrd
fuse?
Lee R. Byrd
