code:
This is a pic with 2 coil mounts from the side w/ no coil on them if you couldn't figure it out. The measurments are for a 14" coil. QA1 says they should compress 1/3 of there overall length. Would this work? Basicaly the idea is putting the bump stops inside the coil. If you think it would work then my next question is, does anyone know of where I can get some bump stops to fit in a QA1 Coil? Don't know the specs off hand, I can get them though.
