I've been reading that you need to grind a bit to fit the 6" lift but do you need to lengthen the drivelines for either of the lifts or is a u-joint spacer enough?
I'm just trying to keep costs down, i'm not made of money.. sure you guys know how it is
Also what would you guys suggest for a locker? I'm shying away from the powertrax and lock-right systems because the pressure-based gear system they use is likely to fail over time but a detroit or tracRight are quite expensive to fit a Dana 70 (actually 70/80 hybrid from what I can tell by reading on the net so far).
Why doesnt anyone make a simple selectable magnetic or physically actuated locker?
Anyways, all information gladly accepted. Thanks
