I have a 390 CFM 4 barrel Holley 4160 model on my 258 and it wants to flood out while I am off roading. Does anyone know where I can get an off road kit for this carb or is there something else I can do? Please help!
The best off road kit you can get is an MC2100... /ubbthreads/images/graemlins/grin.gif
Go to some of your local racer/off road shops and ask around for someone who can work wonders with a Holley or any carb. In my town of 45,000 there is one carb genious who I've sent business to for anything from circle track and drag cars, to a 390 for a 258. My buddy with the 258 has had no problems in three plus years since having it massaged and rebuilt by a pro. It may cost you a bit mre, but should be worth it. Those Holleys are awfully stubborn at angles. /ubbthreads/images/graemlins/grin.gif
Drop the float levels about an eighth of an inch.
Get a spring loaded needle set.
Rebuild the carb to specs.
Mine rarely ever stumbles off road. I am running a 390 holley on built 258.
And -- add the "white whistle" internal bowl vents, the jet extensions, and the external vent tube extensions on top. Set the floats a tad low. There must be a reason Holley has so many accessories to get them to run right.
Holley's a great carb - for clean environments. But they use so many tiny passages that a piece of grit that you'd never even notice in your eye will clog it up. Take along extra gaskets and a catch bowl to catch the fuel when you take it apart on the trail.
The Motorcrafts are simple and reliable -- and use big passages - not real efficient, but they work great off road.
