What is all involved with swapping a 360 into a CJ7 and where can I go to get info/parts etc. The jeep had a 258, t-5, Dana 300.
hey Im doing the swap on my friends Jeep right now...so stand by and I will give you all the pertanant info and small stuff everyone might miss.
Mark (OIIIIO) Langmotorsports(business)
1977/CJ7/Glasstub/460ciFord/C6Auto/NP205/4"LIFT/33'S
I have done this swap, It is probably the best one yet! I used the motor mounts out of a wagoneer,had to cut them downa little, not much with my swap cause a wrangler frame is only 1" narrower than a wagoneer. I went with a 401 instead of the 360. I used the 727 tranny, and the dana 300 bolts right up to it. I had to build my own cross-member. I also have a 2" body lift and still had no clearence problems. The only problem i am having now is the radiator, but i think i figured it out. I am going to use the all aluminum B-cool radiator it goes for about $530.00 Basically everything i have used on my swap is from a 1960's to 1979 wagoneer or grand wagoneer, so it has been pretty easy! If you run into any problems during your swap feel free to e-mail me maby i can help. [email protected]
I just did the same swap. 360 in place of 258. Bolts up to trans. clutch linkage is the same. I replaced the clutch although I think it was the same. The only trouble I had was with the flywheel. The motor must have had the wrong one put on at some point because it had a bad vibration. Bought a new hayes and is ok. Shouldv'e replaced the balancer too. The 360 rebuild got expensive. Had to bore and replace some valves. I used the M.O.R.E. bomb proof motor mounts. I like them but they do transmit a lot of vibrations. The hardest part was spending time with a shop manual and figuring out which wires to cut from the fuse box. Only need a couple--coolant temp, ignition coil, oil pressure, starter, choke , etc.. I used Edelbrock intake and carb- both performer. Works pretty well. It does stall on steep up or down hills though. Maybe a hand throttle will cure.I used a heavy duty V8 stock radiator from the local parts store, with a flex fan for now. Great engine swap with tons of power.
84 CJ7,AMC 360,dual lockers,33" Swampers,5 spd
The fuel line runs down the passenger side for the 258. you will either have to re-route it down the drivers side or rig the line to run over to the fuel pump or run a electric pump.
