I have a fresh 360 and everything to go with it except motor mounts to do my 258 to 360 swap. I am understanding that I need the driver side frame horn for a v8, the passanger side one that I have works.
My problem is I cant find the frame horn anywhere locally. Where can I get one of these?
I do not want the aftermarket mounts or poly mounts.
Actually,
My understanding is that the driver's side is the same for I6 and V8 and the PASSENGER side is what you need. I am sure someone will correct me if I am wrong.
If you are happy with your AMC V8 and are sure that you are going to keep it, I highly recommend the M.O.R.E. mounts. They are a bit pricey, but they are bolt-in and are a serious piece of hardware. They aren't kidding when they say "bomb-proof". They esentially turn your engine into another frame crossmember. Expect experiencing slightly higher vibrations carried into the frame from the engine, though.
http://www.mountainoffroad.com/
Chris
[ QUOTE ]
[/ QUOTE ]
I really don't want the extra vibrations. If it means in 10 years I have to change the motor mounts, so be it. They are $10 each and not hard to change.
You can use the I6 frame horns. I slowly lowered my 360 into the engine bay until it contacted the frame horns and figured out where I needed the holes. I marked the horns, lifted the engine back out, removed the horns and drilled them. I cleaned them up and reinstalled them, lowered the motor back in and presto whammo, it fit like a glove, to bad getting the stupid bellhousing bolts back in wasn't so easy. You will need to use the block mounts from the v-8 and the rubber mounts for a 304. Mine is pretty built and I haven't had any problems with the rubber mounts yet, but I always carry an extra set. If someone wants to hook me up with a set of the MORE ones I'll take em, but I'm just a cheap broke public servant.
Good luck, let me know if you need anything else, I did mine last year.
-web
[ QUOTE ]
You can use the I6 frame horns. I slowly lowered my 360 into the engine bay until it contacted the frame horns and figured out where I needed the holes. I marked the horns, lifted the engine back out, removed the horns and drilled them. I cleaned them up and reinstalled them, lowered the motor back in and presto whammo, it fit like a glove, to bad getting the stupid bellhousing bolts back in wasn't so easy. [...] -web
[/ QUOTE ]
Duh... one more question Web: Any particular reson you removed them for drilling? Also being a "cheap [next-to-]broke public servant", I only have a hand drill... can't I just drill 'em while still attached to the frame rail? /ubbthreads/images/graemlins/confused.gif
It was easier and I believe that I marked the locations on the inside of the horn. That and I wanted to clean them up a bit. I can't really remember to be completely honest, but I think it was a combination of those things /ubbthreads/images/graemlins/grin.gif
