Well, I've torn enough apart to know that you can crack the timming case $199 if your not carefull. You might want to check the condition of your harmonic ballancer as this is what touches the seal. Make sure it doesn't have any nicks in the seal wear area. To replace the rest of the seals in the area, front pan, and timming cover, you will need to remove the cover anyway. I usually knock out old seals out with a wood dowl or tear it apart with tin snips if stuck with RTV. I also use RTV on the seal's outside ring when installing and good thick grease on the lip of the seal. Grease the harmonic ballancer seal area also when installing. It's kinda hard to predict what seal you may have leaking without seeing the mess. You have to take many parts off to do those seals. Check other areas for leaks first.
Pigpen
76 CJ5 360/T18A/Bronco gear D20/D30 big brake disc, locker/D44 big drum working on disc/ factory slip/4inch lift/33's/6000lb winch/All Fiberglass/electric fan/full cage/ appetite for MUD
