The adapter for a 350 to a t999 is $488.35 from advanced adapters. 4wd Hardware does sell bolt in engine motor mounts, but I prefer the weld in ones like MORE sells. Driveshaft lengths might need changed but if you use weld in engine mounts then you could possition the drivetran to where you can use the driveshafts you have.
Tim Springer
1980 CJ7
Tim Springer
1980 CJ7
