I have a 97 Ranger 4x4 4.0 with 3.73 gears I already have 29inch tires on it and I love it. I just bought 35inch tires and I really am racking my brain on How high I need to make her will a 3 inch body lift be enough????? HELP thanks =)
I had 33s on mine with a 6inch body and i went to 36s and they both rub on the frame so not to sure about that sory not to much help u might want to go more though like a 6in body
If you ran fiberglass fenders front and rear you could probably fit them with the 3" body lift. Better would be a 6" Skyjacker Class II and the body lift, or skip the body lift and run the suspension lift and the fenders.
You are planning on regearing, right? 3.73's and 35's is going to be a dog. Absolutely slow. If you have an automatic it's days are numbered. You want 4.56's.
Good Ranger tech:
www.TheRangerStation.com
