I am trying to replace the coolant temperature override switch on my 72 304. It is part of the emission system. I'm not sure the parts guy knows what I need and I know that I don't. Looking for a part number/source. This switch is threaded into the T-stat housing and has three vacuum lines coming from it. Parts guy says that I have a choice of two different temperature settings. My chiltons book does not indicate a choice. I believe the lower temp. choice was appx. 160 degrees. Is a higher temp preferable? (Daily driver)
What symptoms will my motor have if this is bad. Replacing everything any way but just curious what this thing does. If you know what this does, type slowly so I get it.
Thanks for your help
Scott
Scott
