Guest
·All the sudden while going down the road, my '76 CJ with a 304 started backfiring non-stop back up through the carburetor. I could hardly make it back home due to the loss of power. The funny thing is, it idles nice and smooth--seemingly. But as soon as you give it a little gas, look out. I checked a couple cylinders for compression and they were fine. The plugs are all firing and look clean and aren't fouling. This past spring I put a new timing chain and gears from 4WD Hardware. It had been running great since. The vacuum lines seem OK but will check further. The carb and distributor are only a couple years old so should be in good shape. The motor was rebuilt around 10,000 miles ago. Any ideas on what else to check would be helpful. I am really stumped.--Kevin
