Guest
·i have a 2003 honda trx300ex. i just installed a supertrapp IDS2 full exhaust, headpipe and all, a k&n airfilter, and a dynojet jet kit. my problem is if i go to rev the motor right off of an idle it just falls on its face, it won't rev up. now if i increase the throttle really slowly the engine speed will increase, and once the motor is wound up i can freely rev it as i please. i first thought it was lean so i changed the main jet from a 118 to a 120 and then later to a 124, and it just got worse. so then i leaned it out all the way down to a 110 in increments, and still it did the same thing. so i put the 118 back in and started adjusting the fuel mixture screw, and it still does the same. i'm out of ideas and ready to flip out, does anybody have any suggestions on what i should try next. i would really appreciate any help i can get.
Mike
Mike
