I would say it's probably blow-by due to wear on the engine. The oil rings are good, so no oil burning, but the compression rings are worn and the compression is leaking past the rings into the crankcase instead of building up in the cylinders as it should. Plan your rebuild in advance and you can save yourself some money. Another idea is get a used engine and rebuild it while you drive on your old one, and you won't be without for very long.
Loose nut behind the wheel
Born and raised in Jeep-Town
