I would do just like you said at first...
If you leave the horseshoe connector in place, you will be able to use the TFI coil or a can coil in a pinch.
Pretty smart thinking!
Replacing the can coil connector with the TFI coil connecter looks a little neater, but limits you to the TFI coil.
I have one guy that sent me pictures...
He spliced his TFI coil connector in the wiring harness....
But he kept his horseshoe coil connector... Just put male spade terminals on the wires...
Now if he is forced to use a can coil, he just plugs the can coil connector into the TFI connector....
Just reverses the procedure you were talking about...
Nothing like having ALL the bases covered....
Good luck, Aaron....
