Hey Guys,
I am trying to determine what year engine/head is in my 79-CJ-7. The valve cover is held on by 3 bolts on the passenger side that go through the valve cover into the head, one bolt in the front that goes through the valve cover into the head, and 4 bolts with big washers (looks factory) that dont go through the valve cover but the washers seat into a recessed area of the cover and hold it onto the cracked plastic cover onto the head. Any ideas or comments on this???
Kevin Speicher
President
New England 4x4 Club
http://www.ne4x4.com
79 Jeep CJ-7
What you descibe sure sounds like a 258 head, but you really need to give us the head number that is on the side of the head.
I have not looked at my head for a while, so I can't really help you locate it though. Try either a chilton or haynes repair manual as
it should have the location in the front. If you supply that someone here should be able to help you.
Good Luck,
Ethan
