Through my experience, in neutral, with the incorrect(lean in my case)a motor may sound to be running good when you twist the throttle, but as soon as you ride it under load, you will find out otherwise. You need to ride it to find out for sure. Or you can get some tips from someone that has a similarly equiped machine as you, and run what they run.
32:1 is safe. Thats what i run. Ignore those people that run 50:1. The less oil you use, the less lube your engine bearings will see. That means shorter engine life.
-cleartoy
-cleartoy
