Do you have any choke now? If you have electric/heated and just want to rig up a manual, you should beable to brainstorm a bracket and cable for less than $20.00 with a trip to thelocal hardware store. Otherwise, you may find that the kit you linked can be "made" to work, but may bemore of a headache than just starting from scratch on your own.
If you do have some sort of choke housing and linkage, simply block the vacuum passage, remove the plastic cover, and rig up something to pull of the linkage inside.
