ok
my 89 YJ has the little 15 gallon tank (thing is TINY)
a friend of mine got a 20 gallon tank from a later yj with a 4.0L
i see that the fuel pumps and sending units are all different part #'s. Is this just because of the electronics? Do they physically interchage? Can i use my existing fuel pump and sending unit with the newer 20 gallon tank?
i have a lock ring holding my fuel pump in, where as the new tanks have screws
any ideas??
thanks
Boston Mangler
89 YJ With A Bunch Of Goodies
See It At:
http://www.yankeetoys.org/mangler/
Kevin -
Can't say for sure but here are some things to check:
If the 20 gallon tank is taller, then you have at least 2 problems using your sending unit: 1)fuel pump won't be low enough, 2) gas gauge will be inaccurate.
If you have the 20 gallon sending unit, I think you could swap the pumps and then be all set.
Jim
Jim O'Brien
[email protected]
http://www.tidesys.com
