Guest
·I just bought a 1-3/4" coil spring spacer kit for my 1993 ZJ. I was wanting to install it myself. Should I use a coil spring compressor or can I unhook the sway bar and the bottom of the shock and jack up the body, (the jack being under the frame of course) and releve the pressure on the coil spring enough to install the spacer ? Does the coil spring have a bracket or somthing holding it in place ?(just to see, I jacked the back end up under the hitch, with a floor jack and a 4x4 and raised it 22 inches from the floor and the tires were still on the ground). Any info on which way I should do it would be a great help. By the way I did a search and found no help. Thanks
