Yes this sled has YPZ clutches.
What are the part #'s for these springs?
Wht-Lt.Grn part# 90501-555A0-00, spring rate 2.85 kg/mm preload 26 kg
Red-Brn part# 90501-60579-00, spring rate 2.85 kg/mm
preload 39 kg
I wonder if the slightly lower rate will help backshift?
Actually the lower rate decreases the backshift. The stronger the torsional rate on the spring the quicker the backshift.
What do you think about multi-angle helixes
I haven't tried or read anything about multiangle helixes for the Phazer. I don't see why they would not work though.
how did you factor in the 7 tooth drivers to arrive at 2.2
Think of it this way; with 8 tooth drivers the track moves 8x2.52"(track pitch)= 20.16". With 7 tooth drivers the track moves 7x2.52 = 17.64" This is equivalent to a further gear reduction of 7/8. You already have a reduction of 17/33 or .515 so overall this now works out to .45 . If you invert that to get back to the same working figures we are using it comes out to a ratio of 2.2. To avoid all the unnecessary math just multiply the original gear ratio by a factor of 8/7 which is the same thing.
You said my ratio is on the lower edge for my altitude, how did you come to this conclusion?
For every thousand feet of altitude you lose 3% of your power at sea level. Because the Phazer has 56HP at sea level or with the pipe having a supposed gain of 14HP you would end up at 70HP. At 9000 feet you would only end up with 51HP. That isn't a whole lot of HP to turn your track so you need to compensate by gearing down. I personally would not want a lower ratio than 2.05. You just lose too much performance in my opinion.
Tom Hartman has a carb update kit for the Phazer which includes main and pilot jets, main nozzles, and air jets. I don't believe I can remove the air jets from my carbs. Do you have any experience with this matter? I heard that you could move the little black plugs in the carb to effect performance, have you heard anything about this?
I actually had Hartman do a mod on my carbs for a 93 Phazer which I once owned. He bored the carbs, put in new main nozzles (2A), primary nozzles as well as dial-a-jets. He didn't change pilot jets or air jets. I ended up changing the main nozzles back to the stock because it was loading up on fuel and hesitating when I hammered the throttle from idle. I don't know about moving the black plugs in the carbs. All I know is they run pretty bad if you don't have them in place. I guess you could experiment to see what effect they have or better yet check with Hartman.
Have you done any other sled mods besides the 1 ½ track
This sled originally came with a 121" track. I put plastic skis on with carbides. I'm not sure of the make of skis because they were bought used. I had to make a new rubber pad in the mount but they work well. Lost quite a bit of weight too which was very nice. We haven't put in a cold air kit but I heard they work well.
I will scan and e-mail the info I have on springs and flyweights.
