1 - 12 of 12 Posts
I have a 1980 YZ 125 that has an electrical problems, it gets spark then dosent and i cant find any broken wires. I think it might be the cdi box or one of the coils but i dont know how to test it, If you know of any web sites with ways to test it and resistance values or if you know how to test it innput would be greatly apriciated.
LOL, gotta love them voices in your head. What i would do is check all the wires, check the whole layout, electrical tape over all the connected wires just to be sure, that is what i did when my old four wheeler had that problem, and it worked fine.
WARNING
The surgeon general has determined that motorcycle riding will cause: Swelling of the TESTICLES, shrinkage of the BRAIN, and severe trauma to the EGO.
I had a 1980 yz 80 that had the same problem for a while then it died altogether, it turned out to be the magnito was bad and hit the stator assembly, taking out the stators, it was pretty expensive to fix I think it was around $400.00 for a new mag. and stators
Ride hard, Lifes short
Spray WD40 over all the electrican connections and make SURE that no wires are worn through.... if it still dosn't have a reliable spark....
...... You have a couple options.....
See if you can make the bike fit into one garbage can???
sell it to some chump??-could make for bad karma tho-
find another 1980 yz 125 and hope it has good spark....
Get another (hopefully newer?) dirtbike /wwwthreads_images/icons/smile.gif
Good Luck!!
You need a thneed
From Once-ler Industrys
it needs just needs TLC....Tape Lubricant and Cursing!!!
Large balls...the replacement for displacement/wwwthreads_images/icons/laugh.gif
-VVickedVVarrior-
i found the problem it was the main coil under the tank. we alose cleand the bullet conters. and it needed a littel TLC to. thanks daniel
i found the problem it was the main coil under the tank. we also cleand the bullet conters. and it needed a littel TLC to. thanks daniel
Dude, am i still seein double??
WARNING
yes
-VVickedVVarrior-
yes
-VVickedVVarrior-
1 - 12 of 12 Posts
