Ok just went to get a price on a new webber conversion for my 87 YJ. $1300 candian, and thats wholesale price! Ok fuel injection is about $3500. What can I do? My jeep doesn't run right with that stupid carter bbd. What else will work? Can I convert to a new holley? where will I get an adapter or throttle linkage? Please help me god!!!
87 YJ (aka muny pitt)
Do a search on motorcraft 2100 or mc2100. Its a great carb that you can swap on for under 200 bucks( If you rebiuld the carb yourself). Also do a search by username for timinmanitoba(I think thats his name). He wrote one hell of a post on how to swap this carb onto a jeep. IT gives you step by step instructions and tells you about everything you will need.
88 YJ: TR upgrade and MC2100
MC 2100 instructions
Motorcraft / (sometimes called Autolite ) 2100 Carb Install on 258 Jeep
Parts List: MC2100 Carburetor, adapter, air cleaner assembly, throttle arm replacement (fabricated).
This 2bbl carburetor will replace the troublesome Carter BBD and produce a superior idle. It also appears to boost horsepower. It has a good reputation for being reliable and good off road. It is a larger CFM carburetor than the Carter and may produce some hesitation if slammed open at low RPM's. I am very happy with the conversion and thank all of those jeep enthusiasts who helped me with information on this swap.
This conversion will not meet with any legal requirements that prohibit the removal of original equipment or the tampering with emissions control equipment. Check with your local authorities if your vehicle will be subject to inspections in this regard.
The cost of this conversion will be approximately $150 using a junkyard carb you rebuilt yourself, rebuild kit, new air cleaner, adapter plate, and manual choke kit. You may opt for buying a rebuilt carburetor, and I would suggest that you order one made for an AMC 304.
1. Motorcraft 2100 Carburetor - Sources: AMC 304 or Ford 302. Unfortunately Motorcraft does not stamp 2100 anywhere I can see on these carbs. The correct size will have "1.08" in a small circle cast on the drivers side of the carb body, somewhat obscured by the accelerator pump linkage. As difficult as this is to measure in the junkyard, the 1.08 is the size of the venturis. I have been advised that #108 is 450 cfm, #114 520 cfm, and #121 575. This carburetor body is cast from two pieces, a top cover and a combination baseplate / venturi / floatbowl. Apparently you can set / observe the float height by idling the motor with the top cover removed. The top cover has the word "Motorcraft" cast into it on the passenger side above the float bowl.
Power Valve: Be sure to replace the power valve on this carb. It's function is to enrich the mixture in two steps as manifold vacuum drops (signaling load increase). It is closed at idle, and opens to add more fuel as the manifold vacuum drops. If it is not operating correctly, your mixture may be too rich. It is located on the bottom side (front) and is contained under a cap with 4 screws. There is also an accelerator pump on the front, also under a cover with 4 screws, but it is identifiable by the accell pump linkage. I have obtained good results using an oem 2 stage power valve. This valve is longer than the single stage and is original equipment. It is 39mm long from top to bottom and was labeled #16. I have been advised that this means that it will not enrich the mixture until manifold vacuum drops to 16 inches HG. I had to go to a carburetor rebuilder to get this part, it was $5.00. Take in your old one as a sample.
2. Carburetor Adapter - It is the 2 barrel Rochestor to 2 barrel Holley adapter. Also known as the large 2 bbl to small 2 bbl manifold adapter. Summit sells TD Performance Products adapter no. TRD-2086 for $12.75. It comes with 2 gaskets. I replaced the slotted bolts that came in the kit with allen head bolts to make tightening the adapter to the manifold easier. I also used a hardening gasket maker instead of the gasket between the adapter and the manifold (Permatex Form a Gasket 1A). I also used a Ford gasket between the carburetor and the adapter. It is made of black plastic and looks like two gaskets sandwiched together with plastic bushings inside the stud holes. Is this gasket necessary? There is nothing special about it other than that it will seal very well and also provide a lot of heat insulation from the manifold. The hole in the adapter is slightly larger than the jeep manifold. I have thoughts to switch to an aluminum intake manifold from an 84 and blend the manifold to the adapter with a die grinder.
3. Air Cleaner Assembly - This carburetor has a much large air cleaner base than the Carter BBD. It is the standard 5 1/8 " air cleaner base used on most 4 barrel carburetors. Unfortunately the close proximity of the power brake booster and master cylinder limit you to a 9 to 10" (9" preferred) open element air cleaner. If you swap booster to a dual diaphragm GM booster (a great upgrade) you will not be able to use a filter above the carb at all. A K & N 9" filter (2" height) with top and baseplate is $49.39 from Summit (pn. KNN-601110).
4. Throttle arm - The OEM Carter uses a similar linkage, but pulls downward instead of the rear pull on the Motorcraft. You need to simply remove the throttle linkage ball stud from the Motorcraft, bolt on a small metal plate (1" by 3" and 1/8 thick) to the Motorcraft's throttle arm with 1/8" bolts so it is rearward facing, and drill a new hole in that plate for the OEM throttle linkage. I would suggest bending a slight offset into the plate to move the ball stud slightly away from the carb to prevent binding of the linkage rod. In addition, bolt the plate on first then using the linkage rod, mark the plate for the new ball stud hole, remove the plate and drill the hole for the ball stud. Some people have removed the throttle arm from the old Carter BBD and bolted it on, but that seems like a waste of the old carb just to make a simple throttle arm with 3 holes in it. If you are not happy with this carburetor, you may need that old BBD back ( I doubt that will happen if you start with a healthy Motorcraft.)
5. Throttle return spring - I found that mounting the original downward pulling throttle return spring caused binding as it wrapped around the shaft. I instead fabricated a small bracket to bolt to a front bolt of the carb base to relocate the spring to the front.
6. Vacuum hoses - The motorcraft has two ported outlets. One on the front, just outside (to drivers side) of the drivers side venturi idle control screw. I used this ported outlet for my distributor. There is also a ported outlet on the passenger side of the carb base. I am not sure if there is any difference between these two. Mark all hoses you remove from the Carter BBD and connect them back up to the corresponding ports on the MC 2100. The only connection missing from the MC 2100 I used, compared to the Carter BBD is the vapour line running from above the float bowl to the charcoal canister for the collection of evaporated gas fumes. I would suggest plugging this line that ran back to the canister, as the MC 2100 vents the float bowl into the air cleaner housing.
7. PCV - There is a large PCV inlet port on the rear of the carb at the base. If you are looking in the junkyard for a MC2100 be sure that the version you take home is not an older one missing this port.
8. Idle Adjustment - Like most other carburetors there are two screws on the front base to adjust the mixture. Turning them in leans out the idle mixture. Never seat these screws with a lot of pressure at they are needles which will distort and damage the soft metal of the carburetor. I would start with around 2 turns out on each screw and adjust equally from there using a vacuum gauge attached to manifold vacuum to adjust for peak lean vacuum. In other words, turn them out till you get maximum vacuum, then turn them in till it starts to drop off, and back them out slightly from that point to regain peak vacuum. This carburetor is very forgiving for idle adjustments, so don't sweat it.
9. Choke - There was an electric choke assisted by exhaust gas on both of the MC2100 I looked at. I tried the Motorcraft electric choke and it did not seem to work well so I used the Carter BBD's electric choke by removing and reversing the bi-metal coil inside. This worked well till temperatures hit -30 degrees and I switched to a manual choke. I found the electric came off too fast in these cold temperatures and annoyingly came back on after short stops. The manual choke works well.
10. Fuel line inlet - The original fuel line will work fine. You may want to replace the short metal section that screws into the float bowl with a brass fitting.
11. Ford Base plate - There is a cast aluminum base plate with a vacuum operated EGR assembly on it. These are common in the junkyards. As the oem gasket covers all of the bottom of the carburetor except the venturi openings I did not use the Ford base plate. I picked one up from the junkyard just in case. Using it will require lengthening the throttle linkage rod to compensate for its thickness.
12. Miscellaneous - The rebuilt carburetor I used has a small spring on the float assembly shaft which I am told is used to dampen the float movement for rough conditions. The other MC2100 I have for parts does not have this spring on the pivot shaft. Jets are probably available from Ford. They are the same size as used on the 4 barrel motorcrafts. I am advised by a carburetor shop that they have had success with drilling and tapping the carb to accept standard Holley jets. I have not confirmed this detail. After a winter's driving I have examined the spark plugs and am happy with the jetting which is #47's. Both MC2100's from 304 AMC's I have seen came equipped with #47 jets. I have found that for my application the accelerator pump linkage works best set to the third hole down from the top (of four holes) on the arm at the throttle shaft. It's easy to tinker with to verify of this works best for you.
Tim Martin
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, Lockright, full cage & belts, Xenon flares, AMC 20 1pc axles, GM dual diaphragm brake booster
also look into the nutterbypass I believe it's on shortwheelbase.com and maybe look into an igintion swap while you are at it.
BarrelRoll
97 TJ 30" ko's stock but not for long
The complete weber kit should still be able to be found for under $400 American, so unless the canadian dollar took a real hit to like 3-to-1 lately, ay /wwwthreads_images/icons/wink.gif, you got yourself a bad price. (I just looked at the exhchange - $1.52 Canadian to $1 American. Max I would think you would pay would be about $600, unless there are other factors at play.)
Does it really cost you guys that much extra to buy stuff? /wwwthreads_images/icons/frown.gif You guys really need to move to the states. /wwwthreads_images/icons/wink.gif
Good luck
Pete
88 YJ - trails/beach trips only!/wwwthreads_images/icons/smile.gif
79 4WD F250-hauler/tower of my toys
70 Jaguar E-type - the best car England ever made. /wwwthreads_images/icons/cool.gif
90 Honda CRX - Daily pavement-pounder. 42 MPG. /wwwthreads_images/icons/cool.gif
$3500!!!!????
For that price, i'd head to my nearest Jeep dealership. Then i'd tell the partsman that i want a brand new crate 4.0L HO. Then i'd go home smiling with my 195hp 200lb ft of torque fuel injected ultra durable brand new warrantied engine in the back of my ram....if i had $3500....
mike
Give me Jeep or Give me Death!!!
(Will trade functioning organs for CJ-7 or flatfender)
