1 - 8 of 8 Posts
Hi gang .. Can I put a 1.3 head and intake with a webber on a 1.6 shortblock and plan on it running ? I have all these parts and was hoping it would work .. Anyone ?
I'm slowly gathering parts for this conversion now, from what i understand you will need the crank and cam pulleys from the 1.6 due to differences in the teeth (rounded vs squared)as welll as the 1.6 engine adapter,
I dont remember off the top of my head what to do with the Alt\waterpump pulleys but otherwise the rest will be good to go.
1.6 head has bigger exhaust valves for better flow so ya might wanna think about a 1.6 head.
Yep, bolts right up. You will need the 1.6 cam and crank gears as well as the timing belt covers from the 1.6L. It has a higher deck hieght than the 1.3L. I ran this setup on my first sammy and liked it a lot. Very torqey.
I was hoping that the 1.3 head would bolt on .. It should raise the compression as well actually enhance torque (a smaller port with a smaller valve will increase the port velocity (speed of the air)), although it will kill off some top end .. Who needs top end in a sami anyway ;o) ??Cool, I'll let you know how it works .. Thanks guys !!
No problem, I think you'll be happy. It works nice. Still gives a big increase in power, one you can feel.
How much can I mill the head and not screw with bent valves ? Will the timing belt tensioner handle the slack after milling the head ?
I'm not sure about how much you can shave before contact occurs. The tensioner should have no problem taking the slack. You could always elongate the adjuster slot if need be.
1 - 8 of 8 Posts
