· Supporting Vendor
Discussion Starter · #1 · (Edited)
Diode Dynamics LED Lighting Upgrades for 2019+ Ford Ranger
One of America's most beloved mid-sized trucks, the mighty Ford Ranger, has returned! Though it shares a nameplate with the Rangers of yesteryear, that's where the similarities end. A new body, frame, suspension, and powertrain have all been designed to make this the most capable, efficient version ever!​
However, there is still room for improvement. Specifically, with the Ranger's factory lighting! Despite all the new technology of the 2019 Ranger, outdated yellowish incandescent bulbs are still present in the 2019 Ranger's sidemarker lights, front turn signals, fog lights, cargo lights, third brake lights, and license plate lights.
Fortunately, these are all easily replaceable with Diode Dynamics LED upgrades! In just a few minutes using basic hand tools, you can install brighter, more modern looking lighting on your 2019 Ford Ranger. Check out all the LED upgrades we offer for the 2019 Ford Ranger below!
Diode Dynamics SLF Fog Light LED Bulbs
Our SLF LED Fog Light Bulbs are the perfect solution for increasing visibility on the 2019 Ranger. Designed, tested, and manufactured at our facility in St. Louis, the SLF Fog Light Bulb drops right into place of the factory H11 bulbs. The advanced optical design of the SLF means you'll have maximum focused light output, with zero glare!
Available in both cool white and yellow color temperatures, these LED fog light bulbs can be installed in less than 20 minutes! And with 780 lab-verified lumens, the SLF Fog Light LED Bulbs provide FAR better visibility at night!
Diode Dynamics Switchback Turn Signal LEDs
The perfect combination of form and function, Diode Dynamics Switchback Turn Signal LED Bulbs enable a unique dual-color effect on your Ranger! The brilliant 6000K cool white running light alternates with a crisp amber flasher any time your turn signals are activated.
Our 7443 size turn signal bulbs are a direct replacement for your Ranger's stock bulbs, and come backed by our 3-year worry-free warranty. Additionally, these LED bulbs produce 410 lumens of light output, making your Ranger much easier to spot by other drivers!
Diode Dynamics Cargo Light LED Bulbs
Loading and unloading your 2019 Ford Ranger shouldn't be done in the dark! Diode Dynamics Cargo Light LED Bulbs are a drop-in upgrade for the yellowish stock bulbs that provide dramatically better visibility!
Our brightest 921-size bulb, the XP50, packs 410 proven lumens of light output. With Diode Dynamics Cargo Light LED Bulbs installed, you'll enjoy better visibility at night, and a fresh, modern look!
Diode Dynamics Third Brake Light LED Bulbs
The factory incandescent 3rd brake light bulb on the 2019 Ford Ranger lights up in a glow, which takes a moment to turn on. Diode Dynamics LED upgrades provide an instant response, which can alert other drivers on the road earlier, while also providing a modern LED appearance!
Best of all, our 921 size Third Brake Light Bulbs are 100% plug-and-play, no splicing or wiring required! You'll simply remove the stock bulb, and drop in your Diode Dynamics LED replacement!
Diode Dynamics LED Tail Light Bulbs
When it comes to brake lights, brighter is better! Diode Dynamics 7443-sized LED Backup Light Bulbs are a must-have lighting upgrade for your 2019+ Ford Ranger.
Our brightest option, the XP80, packs 510 lab-proven lumens of light output, making it one of the brightest LED tail lights for the 2019+ Ranger on the market!
Diode Dynamics LED Backup Light Bulbs
Don't reverse in the dark! Diode Dynamics 7443-sized LED Tail Light Bulbs for the 2019+ Ford Ranger are plug-and-play upgrades that can make you FAR more visible to other drivers when braking.
At 510 test-verified lumens of light output, our XP80 LED Backup Lights provide drastically better rear-facing visibility than the 2019+ Ranger's factory reverse lights.
Diode Dynamics LED Rear Turn Signal Bulbs
Just like our LED tail lights for the 2019+ Ford Ranger, our 7443-size LED Rear Turn Signal Bulbs can make it much easier for others on the road to spot you when turning or using your hazards. Additionally, the crisp on/off of the LEDs gives your Ranger a much more modern appearance.
With 510 lumens of brilliant amber light, our XP80 LED Rear Turn Signal Bulbs are dramatically brighter than the 2019+ Rangers OEM halogen turn signal bulbs. Get yours today!
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
Thanks for looking!
Jake H.
Diode Dynamics
· Supporting Vendor
Check out our SLF LED Fog Light Bulbs in this stunning blue XT!
Get a more modern look with the 6000K cool white, or a totally unique appearance with our 3000K pure yellow option.
And don't forget to shoot us a PM for free USPS shipping on any U.S order (U.S forum members only)!
Jake H.
Diode Dynamics
