1 - 20 of 32 Posts
Supporting Vendor
Discussion Starter · #1 · (Edited)
LED Sidemarkers for 2018-2019 Jeep JL Wrangler | Diode Dynamics​
We're excited to announce our new LED Sidemarkers for the 2018-2019 Jeep JL Wrangler! Our engineering team designed OEM-grade replacement side marker housings that feature a full strip of high power LEDs to produce FAR brighter, more even light output than the JL's stock side marker light.
Available in clear, smoked, and amber lenses, these LED Sidemarkers are the perfect upgrade to give your 2018-2019 Jeep JL Wrangler a clean, custom look! The popular clear option matches the stock daytime running light housing, giving your fender lights a unique "wraparound" effect. And unlike generic side marker replacements, these also feature OEM-grade retroreflector optics for flawless light reflection at all times!
Computer-designed for perfect alignment with the JL's DRL lamp, our LED Sidemarkers fit exactly like OEM, with zero gaps! Additionally, these are 100% plug-and-play, requiring NO splicing or wiring. Installation is easy -- simply remove your JL's stock amber side marker housing, and our LED replacement drops right in its place!
Features:
  • Modern LED replacements for factory 2018+ JL Wrangler amber side markers
  • Available in clear, smoked, and amber lenses
  • Increased output, with a full strip of LEDs
  • OEM fit-and-finish with factory 2018-2019 Jeep JL Wrangler DRL housing
  • Plug-and-play installation, no modification needed
  • OEM-grade retroreflector side marker optics
  • Engineered and manufactured in USA
All side markers illuminate in bright amber, but there are three colors of lenses, so you can pick the side marker color that best suits your Wrangler!
  • Clear: Matches the factory DRL lamps perfectly! These are clear in color, but still have the retroreflector optics.
  • Amber: Also called OEM, these match your original, and are DOT/SAE compliant in both illumination and lens color.
  • Smoked: A dark appearance, great on black and grey vehicles.
These LED Sidemarkers include everything needed to install them! Each kit features:
Two (2) replacement clear, smoked, or amber LED Sidemarkers
Two (2) replacement push rivets
Best of all, install can easily be done at home! Using basic hand tools and the included installation guide, you can upgrade your JL's side markers in less than an hour. Click the video below for a step-by-step how-to guide! As mentioned above, our LED Sidemarkers are designed for flawless fitment right out of the box, there is no adjustment or modification needed!
Fitment:
  • Fits all 2018 and 2019 Jeep JL Wranglers
  • Fits all trim levels including Sport, Sport S, Sahara, Rubicon, and Unlimited
Diode Dynamics LED Sidemarkers for the 2018-2019 Jeep JL Wrangler were proudly engineered and manufactured in the U.S.A, and are backed by our 3-year warranty! Want to check out more LED lighting upgrades for your 2018-2019 Jeep JL Wrangler? Click here!
Don't forget to shoot us a PM for free USPS shipping on any U.S order (forum members only)! Thanks for looking!
Jake H.
Diode Dynamics
1 - 20 of 32 Posts
