MSD...HELP!! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-24-2001, 03:57 PM
MSD...HELP!!
Just installed my MSD6A and It doesn't work. Did the static test on the unit (coil wire 1/2" from ground and touch trigger wires together) and it fired. When I hook everything back up stock, it runs fine. The problem seems to be in the triggering from the distributer. This is 88 carbed unit. I determined which wire was positive from the distributer by checking for a hot lead with the key on. I could try switching positions with the lavender and green wires at the dist. but I'm afraid I'll fry my pick-up module in the dist. Do I need an adapter because of the elecronic tach? Should I try reversing the trigger wires? Should I just wait until Wed. and call the MSD tech line? By the way, I did do a search before posting. thanks mucho, clyde
post #2 of (permalink) Old 12-24-2001, 04:03 PM
dparker's Avatar
Re: MSD...HELP!!
i have the msd instuctions for a zuk somewhere i will see if i can hunt them up real quick. im running a pro comp tach and i dont need do adapter
and yes if you dont no it buy now i cant spell LOL!
dparker is offline
post #3 of (permalink) Old 12-24-2001, 04:22 PM
dparker's Avatar
Re: MSD...HELP!!
You have seven wires coming out from your MSD 6A
One heavy red - goes to 12v
One heavy black - goes to good ground point
small red - this goes to the wire that was originally on the coils terminal (or ignintion switched 12v)
orange - goes to coil
small black - goes to -coil
white goes to the wire that was originally connected to the -coil IF you are using your original ignition amplifier. im pretty sure this is how mines hooked up
dparker is offline
post #4 of (permalink) Old 12-24-2001, 04:31 PM
dparker's Avatar
Re: MSD...HELP!!
is this how you have it hooked up? http://www.msdignition.com/pdf/pdf16.pdf
dparker is offline
post #5 of (permalink) Old 12-24-2001, 05:02 PM
dparker's Avatar
Re: MSD...HELP!!
im pretty sure thats how i hooked it up i didnt use the tach input though i had to a eamil form msd tech on how to get my pro comp tach to work with the msd and the 4 cyl zuk .
if you cant figure it out buy tonight im going out to the shop and i can look and take some photos that way you well no for sure .i would right now but just left there been up all night rebuilding a honda legend v-6 what PITA!
dparker is offline
post #6 of (permalink) Old 12-24-2001, 05:16 PM
Re: MSD...HELP!!
on my msd box, (msd6A ifn i remember right) theres a spot on the msd box itself where the tach hooks directly up to the msd box.
BiLLy bOb
Head chef for izook events
Do unto others as you want done to you!
If you pack it in, pack it out!
Billy Bob is offline
post #7 of (permalink) Old 12-24-2001, 11:31 PM
Re: MSD...HELP!!
I hooked it up according to the instructions except I didn't know which of the wires from the pickup in the dist was pos. and which was neg. I turned the key on and the black w/white tracer was hot so I used that as pos. and the brown as neg. Since I have the Suzuki electronic tach I'm wondering if that is causing me problems in triggering the ignition.
post #8 of (permalink) Old 12-25-2001, 09:03 AM
dparker's Avatar
Re: MSD...HELP!!
Billy Bob
i have that on mine too but for some reason on the procomp i had to hook it up to the negative side of the coilthats the only way it would work .
i dont no what to tell you about the factory tach seeing how i didnt have 1 thats why i hooked up the procomp tach if you need some photos of my wiring let me now
dparker is offline
