has anyone made a diy panhard bar? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-16-2001, 07:33 PM Thread Starter
Carpal \'Tunnel
JIMZUKI's Avatar
howdy,
i like the way spidertrax's panhard bar looks. but on the other hand i would like to make my own, or copy someone's else, to some what of a degree. i was wondering if someone had made a diy panhard bar? if you have or someone you know has send me some pics. and if you have made your own help me out with some ideas on how and what i will need.
Thanks fer your time,
Jimmie & MONZUKI
"God doesn't have to hand out brains everyday."
JIMZUKI is offline
post #2 of (permalink) Old 12-16-2001, 08:13 PM
Re: has anyone made a diy panharb bar?
I have been wondering the same thing.
I found this site, it's a pretty good read.
http://www.so-calspeedshop.com/catal...t/panhard.html
scott
90 Suzuki Samurai
90 Isuzu trooper
67 14' Richline
guyina4x4 is offline
post #3 of (permalink) Old 12-16-2001, 08:43 PM
Lav25 (Jason) made one and as a result broke a shock tower. I don't know what this says for his fabrication skills[img]/wwwthreads_images/icons/laugh.gif[/img]. Personally, I think it'd be easier and you'd get a better product if you buy one. I know it doesn't seem like much for the $$ but remember that you're also paying for all of their design and fabrication...
AARRRRRRRG! 1987 Red JX 'vert, 4.5 BREEZE SPOA, SJ410 T-case, 31 BFG M/T knock offs, extended shackles (1.6 - 16V eventually)
Capn_Crunch is offline
post #4 of (permalink) Old 12-16-2001, 11:18 PM
bulldogzook
Re: has anyone made a diy panhard bar?
Go to IZOOK they have a tech arrticle on building your own panhard bar. As for the $$$ Why spend $250.00 when you can make one for under 50.00
IF YOUR GONNA BE DUMB YOU GOTTA BE TOUGH!!
post #5 of (permalink) Old 12-16-2001, 11:21 PM
bulldogzook
Go to IZOOK they have a tech arrticle on building your own panhard bar. As for the $$$ Why spend $250.00 when you can make one for under 50.00 they aren't that hard to make!
post #6 of (permalink) Old 12-17-2001, 07:04 AM
I did my Zuk's first panhard back in 95 or so. @ things to keep in mind. Make it the exact same length as your drag link. Try and place it on the same plane as your drag link. This way you don't have the links fighting each other causing wierd handling.
I'd also use at least a 5/8" rod end, and spend a few extra bucks for good ones.
Also, if you're going to weld the bracket to your frame, spread the load out alot. There's alot more force than you'd think on the panhard. It can tear your frame open.
http://www.rocky-road.com
post #7 of (permalink) Old 12-17-2001, 09:19 AM
The broken shock tower was due to a roll. A pan hard bar isnt that hard to do so long as you have the ability to build one. A machine shop with a nice milling machine makes it very easy.
You basically need a couple Heim joints, a piece of C channel or box steel, something for a bar, I used a piece of DOM chromoly steel pipe threaded at both ends for the Heim joint. The basic secret is to mount the bar on the passenger side to the axle, and to the frame on the drivers side. You want the bar to hang down enough from the frame to get it parellel to the axle, but not interfier with suspension uptravel.
Thats the basics, check out the other articles.
"Happiness is a Belt Fed Weapon!"
lav25 is offline
post #8 of (permalink) Old 12-17-2001, 09:57 AM
I built one out of a cherokee sway bar. It was pretty simple, as long as you can weld. However since I run the calmini linkage steering (till I can do a HY-Steer) I placed mine on the opposite side. What is going to cause 'adverse steering' if I keep it the same when I switch steering systems. Maybe I am a little slow, but I can't understand why it's not going to work the same either way. I mean it has nothing to do with the steering system. So what's the problem?
Go Big! If not in your ride, in your heart!
post #9 of (permalink) Old 12-21-2001, 06:05 PM
This is what I did for mine:
http://www.izook.com/tech/aapanhard/aapanhardbar.htm
Moozuki's home page
http://members.home.net/cryburn
moozuki is offline
post #10 of (permalink) Old 12-22-2001, 08:11 PM Thread Starter
Carpal \'Tunnel
JIMZUKI's Avatar
howdy,
thanks for the info everybody. i have an extra steering cross bar(the one that goes from tyre to tyre), and thats what i wnat to use. after a couple of mods to the bar and welding of some tabs i will post some pics.
Jimmie & MONZUKI
JIMZUKI is offline
