Looking at Trackers, what should I look out for? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-13-2001, 07:41 PM Thread Starter
AJMBLAZER's Avatar
Going to start looking for a Tracker. Like the idea of 4x4 with a low range and upper 20's mpg.[img]/wwwthreads_images/icons/smile.gif[/img]
What should I look out for to make sure I don't get a lemon or POS?
What are the known troubles?
I'm in Michigan if that matters any, rust is a bit of a problem on everything here.[img]/wwwthreads_images/icons/frown.gif[/img]
Aircraft, Cars, and Me
AJMBLAZER is offline
post #2 of (permalink) Old 12-13-2001, 08:12 PM
Re: Looking at Trackers, what should I look out for?
I know the Sidekick '89 model first came with the 1.3 engine. Truly underpowered.
I don't know if the Tracker was around in 89.
I would try and stick with Fuel injection though. that would be from 91 on I think...
Calmini 5", 32" TSLs, daily driver, work in progress...
Ionsponge is offline
post #3 of (permalink) Old 12-13-2001, 09:03 PM
wont usually find a lemon tracker... 93 and up trackers had the 16 valve engine, more power and higher top speed.
if you want to go bigger tires, i think you can stuff 235s or 31s with a 2or 3 inch body lift. still get better MPG than your blazer
post #4 of (permalink) Old 12-13-2001, 09:32 PM
AJM!! IFS!!!
KevinOfCanada is offline
post #5 of (permalink) Old 12-14-2001, 04:50 PM Thread Starter
AJMBLAZER's Avatar
KofC, 4x4 and 28mpg![img]/wwwthreads_images/icons/smile.gif[/img] Not many Samurai's around here, and the few that are around the owner's know what they have and expect $$$ for them. The Blazer isn't what I need right now unfortunately.[img]/wwwthreads_images/icons/frown.gif[/img]
Thanks guys, any body else?
post #6 of (permalink) Old 12-14-2001, 05:03 PM
If you were looking for a project you should get a Samurai, then put the 1.6L FI engine. If not, just buy the tracker.
post #7 of (permalink) Old 12-14-2001, 07:11 PM
I just bought in October a 90 Tracker. Its 1.6 w/ throttle body FI. It needed a clutch cable, battery cables and still needs 1 front 1/2 shaft replaced as it gets to making a terrible noise if turned too tight in 4WD. Otherwise the things a straight little car.
Convert tops are negotiable, and cheap to replace thru Ebay. I'd just shake it down carefully for leaks and noises like any other used car. Reason I bought mine was because of the dead simple-reliable reputation they have. Good luck shopping!
Fastone_84401 is offline
