leak out the oil cap?common? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-30-2001, 09:45 PM
my zuk has a leak on the top as if it was coming out of the oil cap!is it?this is my third oil cap!i was thinking it might be my valve cover!what do you all think?
why can't i be happyabortion???
post #2 of (permalink) Old 10-30-2001, 09:51 PM
Re: leak out the oil cap?common?
I would guess that it could be your valve cover gasket or more likely it is your distributor O-ring (where the distributor attaches right at the head). I used orange Permatex and it has never leaked since.
RoBeRt
"Reality goes on without me!"
whazoo is offline
post #3 of (permalink) Old 10-30-2001, 09:59 PM
Look into the hole down onto the valve train. It is not uncommon for the small screws in the rails to come out, causing a small geyser of oil to shoot straight up. Maybe the screw right under the oil cap is missing? Just a thought.
[email protected]
ZOOK94 is offline
post #4 of (permalink) Old 10-31-2001, 06:33 AM
dparker's Avatar
are you sure its oil cap? yes check screw inside motor . you dont have alot of internal presure building up do you? better none as blow by ? it will be hard to keep it from leaking if you do.
RUN IN TO YOU LATER ,and yes if you dont no it buy now i cant spell LOL!
dparker is offline
post #5 of (permalink) Old 10-31-2001, 08:03 AM
My 1988 (early) Zuk was doing the same thing, even after I replaced the cap with a new one from the
dealer... Two weeks ago, I replaced the camshaft/valve cover gasket and did a really good job of sealing it with
Permatex Blue RTV... (A thin coat of RTV on cleaned inside flange of valve cover, pushed the new gasket into
this thin coat... then applied a thin coat of RTV on the outside of new gasket AND applied a thin coat
of RTV to the cleaned edge on the engine wher the camshaft/valve cover sits... I bolted everything down carefully
to specs.. BE CAREFUL... On my 8 valve 1.3, those bolts should be tightened to only 3 to 3 1/2 foot pounds
of torque. DON'T OVER TIGHTEN!! I also replaced the distributor O-ring, $5 from dealer.)
Since then, to my surprise, no oil under my Zuk AND no oil on top either!!!
LeeClark
1988 (early) Suzuki Samurai
"Life is what you make it... make it worthwhile"
LeeClark is offline
post #6 of (permalink) Old 10-31-2001, 08:24 AM
Make sure your PCV Valve is good, If too much pressure builds up in the engine then it could blow some oil out the cap. (It is the doo-hicky that is screwed into the intake that has a hose running from the valve cover.. ) When you
take it off if you shake it up and down you should hear a
rattle. And check the other things people said.
Glenn
87' Zook Spoa,M/L 33's, 4.16 tcase,4.62 gears Camo,Header,2"exhuast, Cam.
Lockers, 8klb winch, -Wildweasel2 NE4WI- club http://www.cs.umass.edu/~glenn/personal.html
wildweasel is offline
