VARIOUS QUESTIONS - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-29-2001, 04:14 PM
VARIOUS QUESTIONS
Zuki gang,
I haven't posted in a while but I have some questions, these are for my stock '87.
Carburetor: Starts without touching gas & revs at about 1500, then increases to 2000 RPM, after warm up settles down to about 1000 RPM. This carb is totally Greek to me, I don't have a manual, any suggestions other than getting rid of the stock carb?
Horn: I tried to replace my stock horn with a louder horn, couldn't get a good horn that was laying in my garage to work. Put old horn back on. Now old horn won't work but HIGH BEAM indicator light comes on when I push horn button. Dome light switch won't light dome light but HIGH BEAM indicator comes on. HIGH BEAM indicator won't come on when I use high beams but they do work. Of course I didn't dis-connect the battery when I was messing with the horn.
Appreciate any help.
Andy Bridgeman Longmont, CO '87 Samurai '88 K3500
post #2 of (permalink) Old 10-29-2001, 04:27 PM
Re: VARIOUS QUESTIONS
Well, I'm not sure about your horn problem, but why are you wanting to get rid of the stock carb. from the sounds of it, it sounds like it is performing correctly. It is supposed to idle high until warm and then drop to normal. Just curious
Following Christ is a lot like wheelin', just follow the road (trail) less traveled!
smitche is offline
post #3 of (permalink) Old 10-29-2001, 05:00 PM
Revving up to 2000 RPM's just seems too high but maybe that's normal for this, it does the same thing no matter what the temperature is. I don't really have plans to replace it but I know many Zuki owners have & don't much care for the stock carb. I have no idea how to make any adjustments to this thing. Who makes a good manual that will show how to adjust carb?
Thanks
post #4 of (permalink) Old 10-29-2001, 05:11 PM
Hey Andy,
You're close to Lonezuk, and also just a few miles from the new Spidertrax location (I think they're at 75th and Hwy 66). There are a lot of folks locally, that can probably help you out (I'm a Sidekick guy, not a Samurai guy - we don't have no steenkin carbeurators).
Bob
95 'Kick 4 Door - Calmini header & exhaust = mo' power! YES!!!
post #5 of (permalink) Old 10-29-2001, 05:21 PM
Bob,
I'm not sure who Lonezuk is. I've been by the Spidertrax shop, stopped by once right after they moved from NJ, that's a good idea. I have a friend in Gilpin Cty, lives in the Dory Lakes area.
post #6 of (permalink) Old 10-29-2001, 05:27 PM
smitty808's Avatar
Don't know about the carb(mine does the same thing!!)...but the wierd light, and horn problems are caused by the fuse for the horn (more than likely). The same fuse works the horn, the dome light, and the high beam indicator!
When I die I wanna' be buried in my Samurai....cause I haven't found a hole it can't climb out of yet!!! [img]/wwwthreads_images/icons/tongue.gif[/img]
http://www.angelfire.com/in3/smitty808
smitty808 is offline
post #7 of (permalink) Old 10-29-2001, 05:34 PM
Thanks, I haven't even looked at the fuse. Now that the time changed I won't want to do anything after work!
So the carb warming up at 2000 RPM is normal?
post #8 of (permalink) Old 10-29-2001, 05:49 PM
Yeah that seems normal, and on some cars, with a blip of the throttle in neutral, the choke turns off, but this likely isn't the case with you since you haven't mentioned it.
<font color=blue>Kevin</font color=blue>
I'm a Chevy Guy[img]/wwwthreads_images/icons/cool.gif[/img]
-See my photopoint stuff-
KevinOfCanada is offline
post #9 of (permalink) Old 10-29-2001, 05:52 PM
Hey, Andy,
I sent you a PM.
Bob
post #10 of (permalink) Old 10-29-2001, 06:08 PM
Sounds like "Greg Brady Syndrome" to me.
AARRRRRRRG! 1987 Red JX 'vert, 4.5 BREEZE SPOA, SJ410 T-case, 31 BFG M/T knock offs, extended shackles (1.6 - 16V eventually)
Capn_Crunch is offline
