two questions - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-26-2001, 04:52 PM Thread Starter
two questions
i've also seen oil leak fixes, but never a very good explanation. my truck leaks in between the tranny and the engine. at least, that's the location that i looks like it's coming from. the tranny is covered in oil. the front driveshaft, and everything else in that area as well!
oh.. one other question. what other vehicles have the same bolt pattern as the samurai????
1987 LWB, stock (for now)
elijah is offline
post #2 of (permalink) Old 10-26-2001, 04:56 PM
Nowhere's Avatar
Re: two questions
There are 2 o-rings on the distributor that keep oil inside the engine, they are commonly found bad. I do not have a source on them...
I'm LOCKED!
Got zook?I do,88.5 spoa'd on 29'shttp://www.geocities.com/bik3r
Nowhere is offline
post #3 of (permalink) Old 10-26-2001, 05:47 PM
Re: two questions
During a recent clutch install I found an O-ring seal inside the bell housing. There is a plate with like 6 bolts in it. If that is where the leak is coming from then when you open the bell housing it should be full of oil.
87 Samurai. S-10 Buckets. Cherry Bomb exaust. 2" lift shackles, 30-9.50 Wild Cats
2000 Chev Tracker 235/75 wild cats
If you ain't wheelin get outa here!
Samurai202 is offline
post #4 of (permalink) Old 10-26-2001, 05:50 PM
Skip
Re: two questions
1. pressure wash engine and trans. Then you can start looking for oil leaks. Could be distributer, rocker cover, head, rear main seal. Probably something high if it's all over the tranny.
2. Bolt pattern, if you're talking about wheels they're 5 on 5.5 ". Ford, Jeep and Dodge of various years use this pattern. Check before you buy. Check for offset some older wheels will not fit over the front calipers and the centers may be to small to fit over the hubs
Skip
post #5 of (permalink) Old 10-26-2001, 06:33 PM
Re: two questions
usually distributor...hey can you post the link to the seals for distr. mines pissin' out too!!!
ROACH Da NastyPimp[img]/wwwthreads_images/icons/wink.gif[/img]
http://http:briefcase.yahoo.com/roachtrax go to crazy pics, and check'em out...e-mail response, reaction, or questions to [email protected]!!![img]/wwwthreads_images/icons/wink.gif[/img]
post #6 of (permalink) Old 10-26-2001, 06:51 PM
Re: two questions
I got my D-o-ring from the dealer. I think I paid $2.00 for it.
AARRRRRRRG! 1987 Red JX 'vert, 4.5 BREEZE SPOA, SJ410 T-case, 31 BFG M/T knock offs, extended shackles (1.6 - 16V eventually)
Capn_Crunch is offline
post #7 of (permalink) Old 10-27-2001, 11:26 AM
Cap34
Re: two questions
You can get those distributor "O" rings from Petroworks. The ones you take out will look like hard plastic.
post #8 of (permalink) Old 10-27-2001, 12:41 PM
Re: two questions
I find that permatex seals the distributor just fine. I'v tried O rings from the hardware store and they don't seem to be able to deal with the heat or the oil contact weakens them.
RoBeRt
"Reality goes on without me!"
whazoo is offline
post #9 of (permalink) Old 10-27-2001, 05:43 PM Thread Starter
Re: two questions
if it was the distributor... wouldn't it be all over the firewall to?... i better take a look... i kinda hope it is.
elijah is offline
post #10 of (permalink) Old 10-27-2001, 06:02 PM
Re: two questions
A good chance it's the distributor caseing o ring. it leaks down the back of the block and hardware stores don't carry that size but i think one for a 1.6 is the same and only a dollar fix
sky_hi_samurai is offline
