Double Cardan Vibration using Hilux Axles - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-25-2001, 01:29 PM Thread Starter
I just exchanged my rear samurai drive shaft or a front Hilux double cardan unit, I am running Hilux axles.
The drivetrain vibrations using the double cardan are extreme compared to the samurai driveshaft.
0) According to the Toyota manual the drive shaft is in phase.
1) The pinion is pointed up twards the pinion using axle shims.
2) The pinion is offset to the left of the transfercase output shaft/flange by 4 inches due to centered differential.
3) The splines on the shaft are tight.
4) None of the bearings in the driveshaft are loose when checking by hand. No slop !
5) Everything was recently greased (yesterday).
6) I rotated the shaft halves 180 degrees but it had no affect.
7) The vibration is at all speeds.
I asked a drive shop in Boulder, Colorado about using two double cardan's on a 20 in driveshaft.
The owner did not think it could be done without having a very short splined section.
Right now the tube is 3.5 inches long with the rest being the double cardan, yokes and spline section.
This is a short OEM factory driveshaft from a 1983 Hilux 4x4.
Any Suggestions !!!!!!
LoneZuk
lonezuk is offline
post #2 of (permalink) Old 10-25-2001, 02:03 PM
Yankee Tim's Avatar
Re: Double Cardan Vibration using Hilux Axles
Is the rear diff pinion pointing directly at the output of the t-case?
Yankee Tim is offline
post #3 of (permalink) Old 10-25-2001, 03:13 PM
Make sure the diff is pointed at the t-case as Tim said.
It makes a huge differnce. also when you had the driveshaft
out did you check the bearing in the center of the double carden? If that is loose or siezed then you will have problems too. NAPA has the center bearing btw. Pain to replace on some of them. Good luck
Glenn
87' Zook Spoa,M/L 33's, 4.16 tcase,4.62 gears Camo,Header,2"exhuast, Cam.
Lockers, 8klb winch, -Wildweasel2 NE4WI- club http://www.cs.umass.edu/~glenn/personal.html
wildweasel is offline
post #4 of (permalink) Old 10-25-2001, 03:28 PM
Exactly how you connected the Toyota driveshaft to the Samurai transfer case flange?
Also check for worn slip-yoke splines.
OILBURNER [email protected]
OILBURNER is offline
post #5 of (permalink) Old 10-25-2001, 04:38 PM
Pooh-Bah
DougO's Avatar
The Hilux rear axle is a centered diff right? the downward angles might be in phase but its the ones that offset it that are probably doing it. Same thing here, except Sidekick rear with a toy front DC shaft
DougO
88.5 Sami with 35" Goodyear MT/R's
89 Sidekick "my lil rust bucket" with 3 - 235/75-15 Goodyear MT's anyone got a pair for sale?!
ICQ 52576971
DougO is offline
post #6 of (permalink) Old 10-25-2001, 04:39 PM Thread Starter
Hi
Thanks for the info.
This is what I do know.
TIA
LoneZuk
lonezuk is offline
post #7 of (permalink) Old 10-25-2001, 04:46 PM Thread Starter
DougO
Do you have a vibration problem or did you have one ?
I think that the double cardan takes care of the drop like you said but not the offset of the differential.
The double cardan cancels itself and the other end does not have a mate for the offset.
LoneZuk
lonezuk is offline
post #8 of (permalink) Old 10-25-2001, 05:00 PM
I Do This For The Glory
JEEPN's Avatar
WHEN do you have the vibration. All the time, acceleration, or deceleration?
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 7" Lift, Locked, Swamped, Rolled, and just generally broken in right!
JEEPN is offline
post #9 of (permalink) Old 10-25-2001, 05:14 PM
If the Hilux axle has a centered pumpkin you'll be able to point the pinion at the T-case in a verticle plane but not in a horizontal plane,
perhaps this is where the vibration is coming from.Tom Woods advertises a "multiple double cardan" (one on either end) driveshaft for
drivelines with compound angles.Try consulting a driveline expert to see what they think.Good luck.
rollerskate
(That's what I was told my Samurai resembles)[img]/wwwthreads_images/icons/mad.gif[/img]
rollerskate is offline
post #10 of (permalink) Old 10-25-2001, 05:36 PM Thread Starter
LoneZuk
lonezuk is offline
