bolt-on perches?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-21-2001, 06:20 PM
bolt-on perches??
hey guys just how do they get the perches to bolt on safely in RRo's and Calmini's SPOA kits?? I have tried to study and figure it out but it seems sortta tough!
Thanx
Studly
92 Zuki/235's/header/cherry bomb exhaust/Still Building
72 fj40/crate 350/33's/discs
post #2 of (permalink) Old 10-21-2001, 08:52 PM
Re: bolt-on perches??
I can only speak to the RRO perches... they are in the shape of an arch (except flat on top because the spring rests on top of them), with the bottoms (legs) of the arch sitting "inside" the tops of the original (welded to the rear end) spring perches. Imagine the letter O is your rear end - you have an upside down U that fits over your O, then plates on the top and the bottom sandwich your spring and rear end in-between. I wish I had a way to draw it for you...
http://www.geocities.com/sloan_3_24_74
sloan_3_24_74 is offline
post #3 of (permalink) Old 10-22-2001, 07:16 PM
yah it is kinda confusin...but if I could make it and not have to weld would it be safe??
Thanx
Studly
post #4 of (permalink) Old 10-22-2001, 07:24 PM
dparker's Avatar
there kits ae made too install bolt up and then after you have eberthing set like pininon agle you weld the snout out of it! it would stupid not to weld your perches thats the easyest way i can put it
RUN IN TO YOU LATER
dparker is offline
post #5 of (permalink) Old 10-22-2001, 07:25 PM
yah but if you look at it man they have chunky stuff man! check out calminies!
Thanx
Studly
post #6 of (permalink) Old 10-22-2001, 07:28 PM
kinda hard to see but check out how thick it is man looks like it stabilizes itself usin the welded under perches man! looks like it is do-able!
Thanx
Studly
post #7 of (permalink) Old 10-22-2001, 08:09 PM
Mine is not welded - you could easily weld it, and I may do so at some point in the future - but I do not have the slightest fear about it being just bolted on like it is now.
post #8 of (permalink) Old 10-22-2001, 09:13 PM
dparker's Avatar
i just guess the wheeling i do i want by $hit toghter dont want a peace of 1/4 stell to give and then your rearens or front end cocks and darn your looking under your rig looking at your driveshafts on the ground saying humm wish i would have welded them but thats my opion i guess it could go the same way if my welds broke.
RUN IN TO YOU LATER
dparker is offline
post #9 of (permalink) Old 10-23-2001, 06:42 AM
Here's the thing though - RRO kit comes with a THICK chunk of steel that bolts under the factory spring perch, then the new perch fits into the factory perch, then the factory shock plate bolts on top. Their special u-bolts then go through both plates. Tough as nails. Or should I say tough as welds?
post #10 of (permalink) Old 10-23-2001, 08:06 AM
dparker's Avatar
but if im not sure they still say to weld it they just it just doent take a pro to do it.heres there link studly that shows a better picture of there perches
http://www.rocky-road.com/spoa.html
RUN IN TO YOU LATER
dparker is offline
