Stock Front OEM leaf spring curvature ? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-01-2001, 11:52 PM Thread Starter
My stock front OEM leaf strings have a negative curvature (center is slightly higher then the ends) like a bell curve. Should they be this way? I just swapped out a set of stiff rancho leafs and do not remember how the OEM units looked.
LoneZuk
lonezuk is offline
post #2 of (permalink) Old 10-02-2001, 12:56 AM
ackerdackerly's Avatar
Re: Stock Front OEM leaf spring curvature ?
I posted the same question recently.
RangerRick responded that straight or a slight positive arch is ok. A negative arch (axle higher than the shackle points or a 'frown') is bad. time for replacement springs...
Ack
ackerdackerly is offline
post #3 of (permalink) Old 10-02-2001, 07:51 AM
Who makes good OEM replacement springs? Does maybe OME make OEM height springs or small lift heights like 1" or 1.5" ?
93 Tracker, ProComp, Calmini, 31's, Thorley, K&N, etc..., aka the donor. Looking for a donee..
Mini4x is offline
post #4 of (permalink) Old 10-02-2001, 09:17 AM
No one makes an OEM replacement spring at stock height. OME does make a smaller 1.5" lift front spring. Be careful though, they make different front springs and the usual one shops know about is the 2" lift spring.
You could take an Add A Leaf and beef up your current front spring pack with it. We carry an Add A Leaf in stock that will revitalize your stock springs, it will also give about 1" of lift on an SPOA vehicle.
http://www.rocky-road.com
post #5 of (permalink) Old 10-02-2001, 03:06 PM
Stock... There shouldn't be too bad of an invert curve. THe samurai comes almost flat from the factory, so a small amount of inverted curve is acceptable, the old full size chevy's came with Invertedly sprung leafs right off the factory floor.
a work of caution with add a leafs.. don't add to many, and too use too thick of a leaf.. Acouple of thin leafs are can be better than one big thick leaf, that will not flex or give to the road's conditions..
Keep it in mind....
-How many injuries or mishaps have happend after saying to you friends, "Hey, Watch this!!"
billduck is offline
