By popular request, Probe brakes - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-26-2001, 08:43 PM Thread Starter
The pics that people request.
93 Probe GT calipers with Samurai rotors
Custom brackets welded to axle. Pics do not show how the e-brake is connected, but maybe I will take some more shots with it hooked up.
[email protected]
ZOOK94 is offline
post #2 of (permalink) Old 09-27-2001, 09:00 AM
GRW
Re: By popular request, Probe brakes
Thanks, By the way is the Probe Rotor close to the same thickness as the sami's ?
I'm just wonderin if you get full use out of the pads, or if you have to toss them when they are half worn ?
Did you use the probe e-brake cables ? Or make you own setup ?
Thanks Gary
GRW is offline
post #3 of (permalink) Old 09-27-2001, 09:05 AM Thread Starter
Probe rotors are the same thickness. Pad life should be normal. I used a proportioning valve from summit($40). Crossed the lines at the connection block at the front of the frame, and took out the factory valve at the rear of the frame. I used the factory sammy e-brake cables. Cut the horseshoe brackets off the end of the cables, and used a 1/4" threaded rod connector with a hole drilled in the center, and two 1/4-20 bolts threaded into either end to clamp the steel cable into it. Also put a small weld on the end of the cable where it comes through the rod connector, for good measure.
[email protected]
ZOOK94 is offline
post #4 of (permalink) Old 09-27-2001, 09:36 AM
Looks a bit tiny, dose the pads have full contact on the rotor?
Bill Forrest!!............Off-Road Champion.
http://www.geocities.com/zukybill/index.html
Bill4rest is offline
post #5 of (permalink) Old 09-27-2001, 11:46 AM Thread Starter
Pads make full contact. The Probe calipers have smaller fluid holding capabilities than others, so pedal feel is awesome. They were designed to stop a vehicle almost twice the weight of a samurai. They don't take up as much surface area on the rotor, but trust me, they stop on a dime[img]/wwwthreads_images/icons/smile.gif[/img]
[email protected]
ZOOK94 is offline
post #6 of (permalink) Old 09-27-2001, 12:03 PM
I would be interested in any and all info,esp with pics[smile}
post #7 of (permalink) Old 09-27-2001, 02:46 PM Thread Starter
$149. for a loaded pair of calipers from Auto Zone. I can snap some more pics later today.
[email protected]
ZOOK94 is offline
post #8 of (permalink) Old 09-27-2001, 02:54 PM
GRW
Not sure if you stated or not, but are those front caliper's ?
Thanks again for all the info Gary :-)
GRW is offline
post #9 of (permalink) Old 09-27-2001, 03:42 PM Thread Starter
Rear calipers with e-brake hookup.
[email protected]
ZOOK94 is offline
post #10 of (permalink) Old 09-27-2001, 06:18 PM
Very interesting.Thanks for sharing the info ZOOK94.
rollerskate
(That's what I was told my Samurai resembles)[img]/wwwthreads_images/icons/mad.gif[/img]
rollerskate is offline
