PSI recommendation for super swamper radial TSL ? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-25-2001, 08:02 PM
the sidewall states it has a 50psi max.
how much should i be running on the street/highway?
currently has 44 front 40 rear,rides ok.
post #2 of (permalink) Old 09-25-2001, 08:23 PM
I Do This For The Glory
JEEPN's Avatar
Re: PSI recommendation for super swamper radial TSL ?
Try like 25 psi, it may ride a little better, the 40's is way too high.
The proper way is to take some chalk and make a mark across the tire. Then drive the Zuk a few feet on level pavement and check the chalk mark. When it's scuffed completely across, drop another 2-3 psi and you're at the optimum pressure for running on the road. Too much pressure and the center will wear prematurely, too little and the sides will wear and not the center.
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 7" Lift, Locked, Swamped, Rolled, and just generally broken in right!
JEEPN is offline
post #3 of (permalink) Old 09-25-2001, 08:52 PM
Keep in mind your Samurai is a couple thousand lbs lighter than the pickup trucks these tire manufacturers figure are going to be runnin their tires. I' go for the low to mid 20's for pressure and you'll find a much more comfortable ride!
http:// www.rocky-road.com
post #4 of (permalink) Old 09-25-2001, 09:12 PM
I'm running 25 PSI on my 32 x 10.5 TSL's.
rollerskate
(That's what I was told my Samurai resembles)[img]/wwwthreads_images/icons/mad.gif[/img]
rollerskate is offline
post #5 of (permalink) Old 09-25-2001, 09:27 PM
Nowhere's Avatar
I've jacked mine up to 30 psi for steering ease.. I need to to the chalk method to make sure I'm not wearing wrong... Time to rotate them too! I run about 5 psi off road.
I'm LOCKED!
Got zook?I do,88.5 spoa'd on 29'shttp://www.geocities.com/bik3r
Nowhere is offline
post #6 of (permalink) Old 09-25-2001, 09:31 PM
these are steel belted radials,will 30psi
overheat them or screw up the handling?
post #7 of (permalink) Old 09-25-2001, 11:03 PM
Like Rollerskate said, mid 20's should work fine. I run my 32x10.50's on 15x7 rims usually between 24-30lbs. Lower is cushier, and higher makes turning the steering wheel easier for the wife.......and on the trail I find 7 lbs gets pretty good flex for the rocks, and I haven't lost a bead....yet......
Hope this helps
Andy Feingold
88.5 Samurai, SPOA,Rancho springs, Rocklobster, full cage, Schroth Harness belts, EZ locker, 32x10.50 Swampers, on board air, Weber, header etc...
post #8 of (permalink) Old 09-26-2001, 06:27 AM
zooky's Avatar
you shouldnt loose a bead with 7 PSI, I ran 3 PSI and never lost a bead. My swampers still did not seem to flex much even that low
zooky is offline
post #9 of (permalink) Old 09-26-2001, 07:05 AM
The commen way to find the "Correct" psi for a tire/rig/wieght is the chalk method Jeepn said.
The first place to start is the manufactures recommendation- You have a tracker/kick right?
what does the door plate say? then try it and see if you get bounced off the road... If so then try them aired down a little and see if that helps the ride.
Glenn
87' Zook Spoa,M/L 33's, 4.16 tcase,4.62 gears Camo,Header,2"exhuast, Cam.
Lockers, 8klb winch, -Wildweasel2 NE4WI- club http://www.cs.umass.edu/~glenn/personal.html
wildweasel is offline
post #10 of (permalink) Old 09-26-2001, 12:40 PM
i just lowered it to 36 front,34 rear.
stock tire pressure is 23/23 according to door sticker.
that would be too low for my tastes.
i'm going to spraypaint a line across each tire and
see how it wears off.that should be better than chalk.
