Dielectric Grease ?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-24-2001, 09:18 PM Thread Starter
CrowHorse's Avatar
Can someone explain how dielectric grease works? If it is non conductive and it gets on contact points, I would think that the circuit would remain open. What's the skinny on it? Thanks....
All Good Medicine,
Crow
CrowHorse is offline
post #2 of (permalink) Old 09-24-2001, 09:52 PM
Re: Dielectric Grease ??
Now I am no expert here, but I have tried this thing out too. I believe, the idea is to get a postive contact, then grease around that to prevent any shorting or air getting to the contacts. However, there is a problem. I used this on some mercury switches that controlled the inertia reals on my 4 point harnesses. The theory......since the switches were mounted near the floor just behind the seats.....smear some dielectric grease on the crimp connectors to keep any water or gunk out. This worked just fine, until some of that grease found it's way into the switches. This made them very irratic, as far as their ability to reliably pass 12v to my belts! This is needed to allow the inertia reals to move! This was most inconvenient. And the fix for my problem was 2 new mercury switches, and well cleaned connectors! So, I think if you have a REALLY Positive contact, the grease isn't bad. I think it was bad at these switches!
Hope this helps
Andy Feingold
88.5 Samurai, SPOA,Rancho springs, Rocklobster, full cage, Schroth Harness belts, EZ locker, 32x10.50 Swampers, on board air, Weber, header etc...
post #3 of (permalink) Old 09-24-2001, 10:20 PM
i have used it on every plug wire connector for years with no problems. also for trailer wiring connectors etc. i think when the metal to metal comes in contact it will allow the current to flow freely but prevents moisture and air to get to the connectors to prolong life.......
build it, break it, then build it better.
post #4 of (permalink) Old 09-24-2001, 11:26 PM
Yankee Tim's Avatar
Die, electic grease!! Die!
Couldn't resist.
Yankee Tim is offline
post #5 of (permalink) Old 09-25-2001, 07:53 AM Thread Starter
CrowHorse's Avatar
Thanks!I am now enlightened!
All Good Medicine,
Crow
post #6 of (permalink) Old 09-25-2001, 09:56 AM
CrowHorse,
I have been away from the BBS for about 6 months(divorce=homeless=new start). I am glad to see you on the board again, your voice of reason is insightful and adds rational to the everyday. Your question about dielectric grease I hope I can answer(I have an AA in electronics). In a capacitor(i.e. condenser), you have thin films of metal rolled up with with a dielectric(air, mylar, plastic wax, etc.). The voltage builds up like a charge until the dielectric breaks down and allows the voltage to pass, thus a higher burst of voltage. The grease does much the same thing, except also keeps out moisture and dirt. This is why it causes resistance for low voltage applications(mercury switches), but for high current/voltage applications, it works great. I hope this answers your question. When I go up to the Island to see my siblings, I hope to hook up with you and tear up some beach with my Zuki's tires. Later bro.
The world looks different when your rubber side up!
-Shawn- is offline
post #7 of (permalink) Old 09-25-2001, 12:04 PM Thread Starter
CrowHorse's Avatar
Thanks for your kind words Shawn.... When you are up in this neck of the woods, let me know and we'll hook up. As far as the beaches are concerned, tearing them up is now in the book of no. The beaches have been hit badly with storms and errosion is a problem as is avoiding piping plovers (endangered species). They only issue beach permits to "bona fida" fisherman and the beaches are patroled to make sure all comply with the regulations. There is even a speed limit on the beach. Some beaches (FINS), restrict tire size. Given the population density, I suppose they must be very restrictive. Twenty five years ago, I could drive from William Floyd Pkwy. to Moriches Inlet via the beach, a good 5 miles or more on world class beaches. No more. Erosion has taken it's toll and the barrier beach has breached several times. I'm not even sure if Burma Road extends to the inlet now.
All Good Medicine,
Crow
