Call me stupid - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-17-2001, 11:11 PM Thread Starter
Call me stupid
But i cant figure out why my sami wont start. Its not the battery, its not the switch, i dont think its the coil and i dont think its the pickup/ignitor but it might be.
With a spark tester im showin fire to the plugs when the key is turned from the off to the run position. I dont show any spark once i turn the motor over. If it was a breaker system i would change the points as it seems to me that it isnt breaking like it should but its electronic and not even napa has the ignitor/pickup for it. Does anybody have any other ideas.
Thanks for any and all help.
Will
"It aint the wand its the magician"
"Keep the shiny side up"
Tread lightly
zukinut is offline
post #2 of (permalink) Old 09-18-2001, 07:43 AM
Re: Call me stupid
You're STUPID!
Sorry but you asked for it.
93 Tracker, ProComp, Calmini, 31's, Thorley, K&N, etc..., aka the donor. Looking for a donee..
Mini4x is offline
post #3 of (permalink) Old 09-18-2001, 07:45 AM
Re: Call me stupid
You're STUPID!
Mini4x is offline
post #4 of (permalink) Old 09-18-2001, 08:09 AM
Re: Call me stupid
OK, you're stupid. (Gee, I bet you're going to get tired of this!) So, you've got spark when you're cranking, but not when you're in the "run" position? I'd check the +12 volts to the "other" side of the coil, to see if you're losing it, when you let off the ignition key. That would be my guess.
Bob
95 'Kick 4 Door - Calmini header & exhaust = mo' power! YES!!!
post #5 of (permalink) Old 09-18-2001, 08:11 AM
Scott_CJ8's Avatar
Re: Call me stupid
check your plug wires, distributor cap and rotor. Pull a plug and crank it while watching to see if it is actually sparking. Are you getting fuel?
Scott Trester - '88.5 Suzuki Samurai
http://RockPile4x4.tripod.com/Scott.html
Scott_CJ8 is offline
post #6 of (permalink) Old 09-18-2001, 08:36 AM
Re: Call me stupid
You are getting spark only when put the key on and off but not when you are cranking?
1- Remove the cap make sure the rotor is turning you might have a blown timing belt, if the rotor is not turning chances are the belt should be replaced.
2- If your distributor is turning put a voltmeter or test light on the + side of your coil and see if you have 12 volts power when the key is in run and start, if it is not there in run you could put a jumper from the battery pos to the + side of your coil if it starts and runs remember you will have to remove the jumper to shut the engine off.
good luck
PS remember you can't be stupid you own a suzuki
post #7 of (permalink) Old 09-18-2001, 07:02 PM
Re: Call me stupid
Your stupid... (all in unison)
lol jking
there, no more name calling heheh
~GooT~
