HOW TO: E-Brake and TOJO PU Axles ???? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-16-2001, 05:49 PM Thread Starter
Hey Zuks with Tojo PU Axles.
How did you connect up the rear e-brake system?
Did you mate the samurai e-brakes cable system to the toyota axles and lever ?
Did you use the toyota system and fab a cable to the cross over.
I believe that the rear e-brake is required to keep the shoes adjusted.
TIA
LoneZuk
lonezuk is offline
post #2 of (permalink) Old 09-16-2001, 06:01 PM
Re: HOW TO: E-Brake and TOJO PU Axles ????
tojo as in toyota?? well on my toyota axle swap i used the stock zuki ebrake cable and adapted it to the toy axle by using the toy mounts/bushing. i also used the stock suzuki rear axle hardbrakeline and mounted i to the toy axle. then your xtended brakelines will bolt right up off your zuk.
build it, break it, then build it better.
post #3 of (permalink) Old 09-16-2001, 11:33 PM Thread Starter
Thank You
I had to make my own hard brake lines for the rear since my toyota axle did not
come with any. Since my zuk has dual rear brake lines, I had to make two lines.
The the outer connector to the brake cylinder is from a toyota and the ends that
connect to the rubber lines are from another zuk.
I did not use my zuks' hardlines since I am building what resembles a kit. So when
the time comes all of the parts can be changed. The zuk is my daily driver so it can
only be down for a weekend.
I will try to use the zuk e-brake cable.
TIA
LoneZuk
lonezuk is offline
