my custom front bumper-to-be - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-31-2001, 11:35 PM Thread Starter
Since there was a recent post on front bumpers here's the one I've been tinkering around with... It's not etched in stone but I already have the base. the top bars and "pre-runner" bar will most likely be thicker. I'm just limited with my paintshop...
AARRRRRRRG! 1987 Red JX 'vert, 4.5 BREEZE SPOA, SJ410 T-case (not sure how I like it), 29 Super Swampers (31 BFG M/T knock offs - eventually) AARRRRRRRG!
Capn_Crunch is offline
post #2 of (permalink) Old 09-01-2001, 12:11 AM
ackerdackerly's Avatar
Re: my custom front bumper-to-be
I am working on something too...
One of the problems that I see is the connection between the front of the frame and the front bumper itself. All there is are the four holes that hold the tie-down "hooks".
I am thinking of using a stout steel tube as a spacer that would go across the inside of the frame tube to better distribute the stress load across the front of the frame. Thus a bolt would pass through the bumper mounting bracket, through the outside wall of the frame tube, through the steel spacer and finally through the inside wall where a nut is attached (or some other appropriate combination since the holes are blind on one side of the frame -- I fergit which...)
Also, looking at someone else's home-made bumper, I noticed that it was not square with the ground when viewed from the side. This is because the frame takes a slight nosedive over the axle and continues at that angle to the very front end. So a mounting bracket must compensate for this angle to make the bumper "square" to the ground.
Lots of details to take into consideration...
Here's my attempt at a design. I am incorporating LEDs instead of light bulbs. I have mounted them in enclosed 2" x 4" 11-gage steel tube sections that are 1 - 3/4 inches deep for lighting. welding begins Sept 1...
Ackerdackerly and
'Ol Yellow Wheels before...
ackerdackerly is offline
post #3 of (permalink) Old 09-01-2001, 12:34 AM
Very nice design, but what are the "threaded mounting studs" going to be used for?
Ryan
"Share your knowledge...it is the only way to achieve immortality."
Cheap Trick - '92 Suzuki Samurai - under construction...always
Stretch is offline
post #4 of (permalink) Old 09-01-2001, 01:56 AM
Zuk Jr.'s Avatar
Capn, looks good, but would be better if you had a winch on the front of it! That is if you want a winch on your front bumper! But, I do like the design of it!
-Brian
ULTIMATE ZUK
Zuk Jr. is offline
post #5 of (permalink) Old 09-01-2001, 07:34 AM
What happened to the other bumper??
ROB
post #6 of (permalink) Old 09-01-2001, 08:15 AM Thread Starter
Those are to attatch a tow bar to. I have a set of those also and am planning on incorporating them into the bumper directly in front of the where the mounting tabs attatch to the frame. I thought that they'd be a great place for mountnig those "D" rings with the screws in them when the tow bar is not being used.
post #7 of (permalink) Old 09-01-2001, 08:23 AM
The stud mounts are could be used for a brush guard on the front, a tire carrier on the back or an overhead carrier (like the one calmini sells that attaches to the body at the door hinges and around the tailgate...) I guess it also could be used for an awning frame for camping.
You never can have enough attach points - sorta like a Samurai Bumper designed by the Swiss Army Knife people.
Ackerdackerly and
